It seems to me that you may need to drive it more.......It could be that it is upset with you for leaving it alone too much.....lol......Mine was suffering the same but now it will be sorry........The storm just hit and the plow is hooked up.......Time to feed her and take her out for some exercise.
  • 2 years later...
I am having the same problem on a 2004 Kodiak 400 4x4.  The drain on the bottom of the carb bowl is leaking a steady stream of gas - exactly as illustrated above.
i bought a new carb off Amazon and installed.  The new carb is leaking the exact same way.
The quad sat for awhile before all this started so it was also having a hard time firing.  I changed the spark plug and now it fires up the easiest when the fuel knob is set to off.  When I turn the fuel knob to on it wants to die and the carb immediately starts leaking again.
I know this is an old thread but it is still applicable.  Any help is greatly appreciated.
You should check the tank and the carb breather hoses are attached correctly, and clear. If they are in order then I think you need to take the carb off and clean the float needle seat and carb drillings.
I confirmed the tank breather hoses were attached correctly and clear and then realized I swapped the bottom gas inlet hose and the upper breather hose.
After I reconfigured the quad is running like new.  However I did discover that gas leaked into the oil.  New oil and filter in order.
Thank you Mech!
I generally warm bikes up and the fuel evaporates real quick..  I don't ride them but just let them sit with the idle a little high.. The type of bearings they have don't require pressure but flow, and the thinned oil doesn't do any harm in a short time of running..
Depends how full of oil they are though of course..  haha.. If the level's so high it will be a problem in itself (crank dipping into the oil and splashing/turning it to a mist), then I drain it..And change it.
On 12/10/2022 at 4:39 PM, Krominator said:
I am having the same problem right now.........With this garbage fuel that they are selling us, it is important to put a good additive in the fuel to keep your carberator from gumming up.......I think the ethynol in the gas turns to gunk when the machine sits for a while and it can make your seats sticky causing the float to hang up.......I have never had these problems before they ruined the fuel with corn juice.
You are correct on the fuel issue. Ethanol is a hydroscopic fluid and will attract moisture out of the air. The big issue with Ethanol is that it will mix with gasoline but it will not combine with gasoline, what this means is that the gasoline and Ethanol will separate if left still. The  sloshing around keeps them mixed when driving. When a vehicle sits for a month or so the Ethanol and moisture it's collected goes to the bottom of the tank and that's where the fuel pickup is. The bottom line is now you have water in your carb. Always use a fuel additive/stabilizer to your fuel
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
    • By Tinkeringreg
    • By kaidella
