on my 95 bigbear. i ust completely cleaned every nook and cranny. what is the proper carb adjusting procedure? how many turns on the air screw, and setting the cable, how far up is the slide supposed to be?
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
    • By Ejwill
