The event will be held Friday May 4th noon to 8:00pm, and Saturday May 5th 9:00am to 8:00pm. There will be about 100 vendors, about 10 sponsors, test rides, swap meat, and a quadmasters stage with pro runs, amateur, and a competitive event. The courses include a boulder run, bridge crawl, mud run, trailer course, log moguls, and an urban run.
The event is to be held at the Benton county fairgrounds (near Osseo MN).
For more info you can check out www.atvam.org
    • By TimothyLindblom
      Timothy
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
    • By lewisrssll
      View File How To Perform Compression Test
      How to perform compresion test
      Submitter lewisrssll Submitted 10/06/2024 Category Other ATV
    • By anthonyd256
