Just because it was buried in a ride in pa post here is the info. This event is to be held at Mountain Ridge Trails Resort the same place that hosted Quadfest years ago. I think wind dig will be toned down version of quadfest or at least that is what they are aiming for. Not sure if the numbers will reach 5,000 like past years but I figure it's something to check out.
Here is the information from the website: Mountain WindDig Family ATV Ride
The WindDig Family ATV Ridewill be held July 16-17-18, 2010 at Mountain Ridge Trails Resort; It is an ATV exposition that is meant to provide an exciting weekend for ‘everything ATV.’ There will be ATV trail riding, skill events, a scavenger hunt, Saturday night entertainment, and motocross time trials along with a vendor show including OEM and dealerships in the area.
    • By PIYIRIO
    • By dalton7545
    • By marcosphoto
