    • By Tinkeringreg
    • By kaidella
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      But when trying to start in neutral, there is no click or attempt to start with the push button.
      However if i pull up on the shifter (not hard enough to shift into first though) the neutral light goes off and the start button works and it starts fine.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
      Thanks for any help you can provide.
    • By ruslan1o1
      Hey everyone looking for a suggestion of where i can start looking. But first I'd like to explain what happened. Took the bike this morning got it started in 6 degrees celsius in 6-7 kicks? No choke. Drove 6km and when shifted to next gear bike decided to just shut off, stopped checked everything out seemed good, started first kick and on i went, drove maybe another 2km bike did same thing but this time it took me 10-15 kicks to get it started, on the third time after a kilometer decided not to start at all. Kicked it like a 450 a couple hundred times, nothing. So far checked gas is good, bypassed fuel filter and on/off valve to eliminate that problem, hot wired the kill switch in case something got corroded there. Nothing. Any suggestions would be welcomed. (Heard valve adjustment are a must do?)
