My Eiger, is not running well. It starts fine, however it kills whenever I throttle it up.
When I hit the gas it sputters and backfires.
I have checked the air filter, it is fine, there is no exhaust impedance, the fuel is fresh and clean, any suggestions?
Thanks in advance.
If you get a bad batch of gas, a month is long enough for a little varnish to build up in the carb. Checking an cleaning the carb shouldn't cost you anything, so I would still start therer. Also check any rubber parts like diaphragms and o-rings for problems. Also, look at the float plunger, it could be hanging up and not letting fuel in the carb. If you don't find any issue in the carb, you are probably looking at a bad CDI, pickup coil, or some other type of ignition problem.
Hatchednick-
For me it was a sticky choke. I cleaned it with some carb/choke cleaner and it has run great since.
well for me i sunk it in the lake and ever since then it has ran like sh** when its high rpms it will run fine when it low rpms it wont when its idleing it bakfires threw carb and as soon as the bike warms up you hit the gas bike backfires and dies carb has been cleaned with rebuilt kit at deal 3 times has done nothing flywheel is fine toook hole motor apart and cheaked it
Hatchednick-
I'm glad to hear that you had solved your issue Wizard...:yes:
I agree with DD, check your valves/compression/timing. Stupid question...did you dump the fuel after you sank it? Change the plug?
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
    • By Dsluder
    • Guest
      By Guest
      I have a 2022/23 Honda Rubicon, and was wondering if there is an exhaust deflector available.  I have a rear basket w/ chainsaw mounts, a winch on the rear, and a hitch.  When I am working at the rear of the quad, the exhaust puffs and hits us, while we work.  It is quite annoying and wound like to be able to direct the exhaust downward.  Is there anything that you know of that would work w/o creating any back pressure that might disrupt the engine?  I’ve been searching for something like this, but can only find ones for small engines and silencers that would interfere with the winch.
      dave
