    • By marcosphoto
      My 2004 Yamaha Grizzly 660 is still going strong but the battery has not been holding a charge. I replaced it a few years back and have been jumping it lately but after sitting for a few days, it drains out. I recently purchased two car batteries from Weize directly because it was a good price for an AGM. I looked on weize for a YTX20HL-BS and its an AGM at $59.99. I believe they have a promo code you can find. Found it cheaper on Amazon and intalled it yesterday.
      I ended up buying the same one on Amazon which is $49.99 with a $20% coupon bringing it down to $39.99, which is a pretty good price for an ATV AGM battery.
      Just a heads up if anyone needs a new ATV/UTV battery going into winter.
      YTX20HL-BS fits a a good amount of models.
      Arctic Cat:
      Arctic Cat Alterra Arctic Cat ATV 450 Arctic Cat Alterra TRV Arctic Cat Alterra CORE Arctic Cat Alterra XC450 BRP (CAN-AM):
      BRP (CAN-AM) Outlander BRP (CAN-AM) Outlander 660 EFI BRP (CAN-AM) Renegade CF Moto:
      CF Moto Cforce 500 Honda:
      Honda TRX680FA Four Trax Rincon Kymco:
      Kymco Maxxer 450 Kymco MXU 450 Kymco MXU 500 Kymco MXU 700 Polaris:
      Polaris Sportsman Polaris Sportsman Touring Polaris Sportsman XP Polaris Sportsman X2 Yamaha:
      Yamaha Kodiak 700 Yamaha Kodiak 700 EPS Yamaha YFM40FB Big Bear Yamaha YFM40FW Kodiak/Automatic Yamaha YFM40FWN Big Bear Yamaha YFM450FA Yamaha YFM45FA Kodiak Yamaha YFM45FG Grizzly Yamaha YFM45FX Wolverine Yamaha YFM45KD KP Kodiak Yamaha YFM600FW FH Grizzly Yamaha YFM660FP FR FH FL Grizzly Yamaha YFM66FA FG Grizzly Yamaha YFM700DE DH PE PFPH PS Grizzly Yamaha YFM700GD GP Grizzly Yamaha YFM7FG Grizzly Yamaha YFV600FW Grizzly Yamaha YMF5FG Yamaha YFM550PE DE DH Grizzly UTVs:
      Arctic Cat Prowler 500 BRP (CAN-AM) Maverick BRP (CAN-AM) Traxter DPS BRP (CAN-AM) Traxter Base BRP (CAN-AM) Traxter STD BRP (CAN-AM) Traxter BRP (CAN-AM) Defender Kawasaki KAF620 Mule 3000 Kawasaki KAF620 Mule 3010 Kawasaki KAF620 Mule 3020 Kawasaki KAF620 Mule 3010 4x4 Kawasaki KAF620 Mule 4010 4x4 (CN) Kawasaki Teryx All Models (CN) Kymco UXV450 Kymco UXV500 Kymco UXV700 Polaris RZR Polaris RZR 4 Polaris RZR S 800 Suzuki 2005 QUV620F
    • By p5200
      Hello folks, I have a Polaris 500 Scrambler. Not positive I need a new battery.  The folks I got the ride from said they put a new battery on it right before selling it to me. It's been a couple cold months before I tried starting it. After jumping it now, I let it idle plus revved it quite a bit for about 20 minutes. Then I shut it off and tried to restart barely turns over and that's it? Am I not giving it enough charge time maybe need to actually ride it? The battery on it is a Continental CTX9-BX. I lf a new battery is needed would maybe Amazon have a decent one? Thanks!
    • By GTX-Racer
      I am looking for a front battery cover for a Suzuki Quadrunner 250 (year unknown).  It has the headlight on the handle bars and no speedometer.
    • By akira gatewood sr.
      Just bought 07 450ER and took it out for a ride(20 min) came back in and saw oil on swing arm. Upon further inspection found it was coming from air box. Wondering if it could be to much oil ( draining and refilling both tomorrow) , or possibly something worse. Guy isn't answering any questions now smh.. thanks ahead of time
