everything sounds ok spark ok when it is out of hole exhaust has pressure and suction at intake but will not start or fire even with starting fluid cannt figure it out and can not find service manual download free do not know if timing is ok can not figure out how to line up marks with out instruction
I believe it will be on the left hand side as you are sitting on the machine. There should be timing marks on the flywheel. There should be a bolt that sits over top of the stator that you can take off and see the flywheel, there should be timing marks on the flywheel, there should be a "T" that shows up in the hole where the bolt goes, that will tell you that the motor is at TDC.
    • By Tinkeringreg
    • By oxidized_black
    • By leecon
    • By KSIM
