I am not married yet (no duh 😂 I'm 15).  If I got married, I wouldnt want anything fancy-  probably just a band...  wouldn't take it off for anything probably simply cause I would forget that it was there lol
I can't wear one as an electrician. But I do wear mine all time. Even riding. I only take mine off to shower cause who likes soap in their ring. My wife on the other hand, doesn't wear hers because she is a paramedic.
I never word a ring when I was a mechanic, but I now wear a silicone ring all the time except on special occasions and then I put my good one on.
At one of the car dealerships I worked at a young guy got married. When he came into the shop after the honeymoon, he had on a gorgeous ring.  I told him to remove it for safety reasons, but he said "I will never take if off because it is a token of the commitment to my wife".  To make a long story short, before the week was out he accidentally grounded a wrench (which was touching his ring) between the terminals of a battery and destroyed the ring and give himself a third degree burn.
I had a neighbor farmer who pulled the end off his finger when getting his rind caught on a through bolt on the bed of a grain truck when he jumped off the  side.
Ladies and Gentlemen, your spouse would rather you not wear the ring doing certain things than you having no finger to put it on.
  • Haha 1
I would suggest to the ladies to leave their engagement rings at home when  out riding . As others have mentioned  it's too easy  to lose the  stone(s) out  of engagement rings,whether you wear gloves or not. Nobody in their right mind wears  rings in the mechanical  and electrical  trades while on the  job , and nobody should wear them  when  doing anything recreationally where there is a  chance of snagging or shorting out their  ring. It's far too easy to end up  with no ring......or finger.
By all  means ,  wear your  rings  socially  but  leave them  home when  out riding or camping.
1 hour ago, lemoncap said:
I wear my piston ring on my ATV all the time:)
we should start a thread to the atvs asking if they wear they're rings when riding....  its just not fair that they can I we cant... (or maybe I should say best not to)
  • 4 months later...
Been Married since 11-12-11
Wife knew I would not where it often so we did not go crazy on it.
While at work not allowed,and at home I work a lot in the garage.
only time I where it when we go out.....and then I forget it.
  • 4 months later...
I have a silicone ring that I swap out for the real deal when doing any outdoors activities, working in the garage, etc. Have had a couple close calls with ring avulsion in the past and I like all of my fingers, so silicone rings it is for me.
Married in 74 wore it two years almost tore my finger off at work when it got caught on the top of a shelf upright when I was jumping down. Had it repaired and has been on a chain around my neck ever since lol.
On 8/25/2012 at 7:33 PM, marioweldinginc said:
I dont wear a wedding ring at all. It was a requirement not to wear one or any jewelry when I was working but then it became habit not to wear it. I do wear it when we go out. My wife doesnt wear one either.
I wore a titanium ring originally because it was a possibility I'd ruin another one easily by getting it squished in just tight enough places I wouldn't worry about my finger but did have to worry about a ring.
On 10/15/2012 at 7:51 PM, mxquadmom said:
When I ride I use to wear my ring but not anymore for 3 different reasons:
#1 - After 18 years of marriage taking my ring off is no biggie :cute:
#2 - The blister/calloused hand I get from riding really hurts
#3 - I always end up damaging/bending the ring if I ride long enough.
1) Yeah, my wife is not insecure about the wedding ring and with her metal allergies often keeps hers off unless we're going out.
2) Same if I end up swinging a hammer a bunch in a day
3) see above reply Î
On 2/24/2019 at 2:55 PM, Frank Angerano said:
Tattoo that thing on. No more worries !
Still keeping that in the consideration list for next tattoos on the both of us.
This is what I eventually ended up doing. The combination of my new brother in law getting a set for working on their farm and me getting a bit fat and having my original ring start to hurt I just moved entirely to the silicone rings so I keep them on a lot more often now. I also don't worry about losing it when I pull off my glove on a cold day.
I only pull mine off when I forget and spray carb cleaner all over my hand and 2 minutes later my finger catches fire....because I forgot to take my ring off for the 95th time as my oldest laughs and says "I wondered how long it would take for you to pull it off THIS time"
  • 5 months later...
I never wear my ring when I ride. If something happens and I have to fix something I then would need to take it off and it would get lost. Refuse to work on anything wearing a ring, have seen to many injuries with a ring getting caught or causing an arc
I don't wear mine. I used to, until I lost my big diamond. Not sure if it got caught on the inside of my glove and came out and was lost or what. Replacing that diamond sure cost a pretty penny....     I am actually divorced from him now so I don't wear any of it anymore lol.
I have been married for 61 years and have not worn my ring for at least 50 years due to my job.  I caught it between a car battery and ground one time and after I recovered from that I restored the ring an started wearing it again. Then I kept getting it caught in the depths of the machines I was working on and nearly lost a finger so I do not wear it. I probably should wear it on a chain around my neck!
Wear mine, but it's bulky and thinking about either a thinner one or something in a different material for work and riding and the like.
Looking for an engagement ring for the gf. However I became paranoid of metal rings since my fathers told me his buddy had the ring caught and lost his finger. No thank you now I’m trying to explain to the gf how I’ll wear a cheap o ring as my wedding band. 100 of them for a few dollars and I don’t have to worry about losing it or a finger.
  • 9 months later...
I am an industrial technician which includes electronics, mechanics, and machine work. I no longer wear my ring since I got it between an auto type battery and ground then getting it caught in machinery guts several times, and nearly pulling my finger off a couple of times.  I figured I could leave it off rather not having a finger to wear it on. It is on a chain around my neck when I am not working.
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
