You need to fix the carb problem you are having before you worry about the idle adjustment. Now, when you say idle screw, are you talking about the fuel screw on the bottom of the carb in front of the float bowl, or the hand screw for the throttle adjustment? Has it been a while since the machine was run, because it sounds like it is not getting enough fuel. A good carb cleaning will probably help if this is the case.
You guys are right it has definatley been sitting awhile not sure exactly how long I sold it to my brother in law a couple years ago he didnt pay me so i went and got it he said it had been sitting but it ran great before he parked it he said he parked it because clutch cable broke(which I fixed) and to start it you have to cross it over at the syloniod ( I put another one on) but it didnt fix the problem do you guys have any suggestions on what that may be as well I actually thought of cleaning the carb what do you suggest to use for that ? tearing it down and soaking it in carb cleaner? I did drain the gas and put fresh in before I tried starting but I am sure there was fuel sitting in the carb all that time too just curious I appreciate your time and again thanks
Johnnie
Edited by warriormo2000
First, take it completely apart. That means EVERY part that comes off. Soaking the metal parts in a bucket of carb cleaner is ideal, but if you don't have a bucket already, they can be expensive. A gallon bucket of Chem-dip goes for like $40 up here. A can or two of regular carb cleaner will do fine as well. Do you best to remove any fuel residue from all areas of the carb and make sure all passages are un obstructed. The best way to make sure everything is clear is to blow compressed air through them. If you can't blow through some of the smaller holes, ie. jets, use a small piece of wire or carefully poke it out with a small drill bit. Make sure all your gaskets and diaphragms are in good shape and throw it back together. You may need to clean the tank and petcock too, and it probably would be a good idea to replace the fuel filter too.
    • By carkivey3
    • By EasyE
      need service manual 1987 suzuki lt230e
    • By Malta54
      I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
      Sparking Plug
      Fuel Injector
      Fuel Pump
      Fuel Filter
      Fuel Valve
      Fuel lines
      Power Control Module
      The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
      The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
      Would greatly appreciate any assistance.
      Thanks in advance.
