So I landed a jump the other day and the rear shock compressed but took about 30 seconds to recoil. After messing around with it for a while I jumped it again and it started recoiling properly again, but after a few hours of riding it went back to recoiling very slowly. So is rebuilding an option or would it just be cheaper to buy one for $99 on ebay? Also what could have happened internally for something like this to happen. btw its a fox shock with piggy-back reservoir.
    • By Gunny
      Hope you enjoy the video ....
    • By KdlH
      Following on from this thread;
      I've finally got around to pulling the clutch cover off to have a look at the shifter ratchet mechanism. The screw holding the pinned star wheel has come loose and the wheel flops about. Unfortunately the keyway on the shifter cam has broken on both sides, I found both pieces.
      Anyone had this problem?
      The keyway on the cam "ramps" out, so I'm thinking of making a slightly longer key with a ramp ground into it. I'll put it back together with retaining compound. It may not work but I think it's worth a try.
    • By gbanker
