Maybe something is not connected properly, could be a bad relay, or the switch itself may be faulty. A test light or multimeter could be a big help in diagnosing your problem, just follow the power from the battery through the switch and to the winch motor, you should be able to find where the power supply is interupted.
    • By Tim Keiper
    • By Panupong Pradchaphet
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By motox88
