By p5200
Hello, would this be a good Master Link tool for pressing master link plate back on? I've seen others made of aluminum but thought this one might hold up better. Thanks! 🙂
https://www.amazon.com/BARTOO-Motorcycle-Convenient-pressing-Alignment/dp/B0C4FB1V7D/ref=sr_1_3?crid=1KRW04WLD82EI&dib=eyJ2IjoiMSJ9.4Y2_vOEctIVv0vgmajSYXL844RphCjGBrMsiewv7Z1sVIMYMM5OQNBL0cXeHLmUDsnKMO5JffQPEP8vl4xuxCUczEfKGgw4r-MYmLgCzydGm9sHnK8hX7o1AqXunVpgpR8RrfQ8noUmfLyoxTqUcrl9tj82jDWeB5CL1rifd--ufsiyaWkBl4omd_1qyx7a97BvOTogpK40NTm9BfKjSt2H5mXrjEnhEOcxSYxUHiRx61KbfDBaA8B9CvwQjM3qGIf4Ay1zWxxPURTnX5qjhddcAADez5JNCFVrUYeLE-7M.sFaeyu09Q7O8v9B0NPjaDYDuHqVqE4uyxspDEpxBs6U&dib_tag=se&keywords=chain+press+tool+for+polaris+500+scrambler&qid=1709916341&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sprefix=chain+press+tool+for+polaris+500+scrambler%2Caps%2C198&sr=8-3
By p5200
2000 honda trx300ex. It's been sounding like it's been cranking too fast and not hitting at all. I took the 2 valve adjustment caps off and while cranking, the valves don't move at all. Getting good spark and fuel. Surely, there should be movement with the valves opening and closing. Am I correct on this assumption? Thanks folks!
By JesseWeber
I have a Yamaha grizzly 600 that smokes and seems to have a rich mixture. I can't find that it has any high speed mixture adjustment. It came with a carb which was supposed to be new. Would a new carb have such a problem? The float had to be set quite low to avoid overflowing the bowl which could suggest a poor needle valve. I don't know if that related. Anybody know what my problem is?
By BenderIsGreat
Hey all, I've been working on getting up enough posts to download the service manual, but in the mean time, maybe someone is interested if giving me a few deets in a reply? If not, no worries.
I'm look to confirm a couple things that I've picked up from Google searches.
First, I've heard that the factory mixture setting on the carb for this bike is 2 full turns out. Can people confirm? I've also heard that it's a fuel mix valve, not air, so screw in to lean, out to richen? Is that correct?
And for the valve clearances, I've heard two different specs, one is intake 0.004" and exhaust 0.006", and that other I heard from a youtuber who claimed this bike had 'very tight' valve clearances, said 0.002" intake, and 0.004" exhaust.
If anyone wants to comment on the above, I would be appreciative, if not though I'll keep posting until I can download that service manual
