Here are the specs:
Carburetor BSR36
I.D. Mark 5YT1 00
Main jet #142.5
Main Air Jet #35
Needle-clip Position 5JFC39-2
Needle Jet P-0M
Pilot Air Jet #65
#165
Pilot Outlet 1
Pilot Jet #22.5
Pilot Screw (Turns Out) 2.25
Bypass 1 0.8
Bypass 2 0.8
Bypass 3 0.8
Throttle Valve Size #105
Starter Jet #70
Fuel Level 4 - 5 mm (0.16 - 0.20 in)
Float Height 13 mm (0.51 in)
Engine Idling Speed 1,450 - 1,550 rpm
Vacuum Pressure at Idling Speed 33.3 kPa (9.83 inHg)
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
