My Buddy who is stuck, his 4wheeler started right up and has not missed a beat, we were a little worried when it stalled in the water like that but it was ok. Its amazing what you can put these things through and they just keep going.
    • By marcosphoto
      Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
      It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with  electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
      Does anyone here have any expierience with these.
    • By flyinbrian365
      The files it too large to upload so here's a link to my dropbox.
      Hope this helps someone!!
    • By SouthARriverRat
      Looking froward gaining more knowledge and seeing projects being built. Currently resurrecting some kind of Suzuki 230 quad. I believe. lol. Been sitting at the edge of the woods for 15+ years. Riding a all original 84 Honda atc 110
