I am trying to install a motor from a 200S on my 200M. It is supposed to be the same thing without the starter. On my 200M, there is a black/red wire (from alternator), which the 200S has also. On my 200M, there are 2 yellow wires, which I think go to the regulator. On the 200S there is a yellow wire and a green wire (from alternator). The 200S has no regulator and no neutral wire. My question is what do I do with the 2 yellow wires from the 200M bike, and the 1 yellow and 1 green from the 200S motor? I'm assuming all these wires are to get the alternator to work. Sorry I could not figure out how to post the wiring diagram from the 200M, the whole manual is to big. Thanks
I would just swap the stator form the original motor into the new one. You could just keep the chargind system intact, that way you could run the lights without starting the vehicle. You could probably swap the starting system to the other motor by swapping some hardware with it, ie. starter, side cover, flywheel etc.
If there is some reason you can't or don't want to do that, the wires that come from the stator would go to the ignition and the lights. The colors may be different, but the plugs are probably set up the same. If you have a diagram for each motors electrical, you should be able to figure out what goes where. As far as the regulator goes, if you don't have a charging system, you don't need it. I would just remove it from the bike if you aren't going to use the battery and charging system.
Thank you very much for your response. Man, you really got me thinking now. Ideally, I would love to be able to take the electric starter from the old 200M and put it on the 200S, but I don't know if it is possible. I know the flywheels are different, because I can't take the recoil starter from the 200M and put it on the 200S. Is the starter gear assembly deal that the recoil starter bolts to able to be swapped? If so, what would I do with the neutral light wire, because I don't see a neutral sensor on the 200S.
I tried to see if I could put the electric starter on the 200s, but it could not be done. I'll just find a used recoil starter for the 200s, because the motor I bought did'nt come with one. I'll just get it running first, and then I'll see about getting the lights to work. I know the green wire from the 200s stator goes to ground according to the diagram I found on 3wheelerworld. I would like to leave the regulator the way it is, because I plan on hopefully repairing the 200m motor. Any more help with wiring would be appreciated.
I would just swap the stators and use the regulator. The problem is that the regulator is also a rectifier, which changes the A/C current that comes from the stator into D/C current, so the electrical systems are completely different. If you can swap the stator from the electric start motor into the pull start motor, you can just wire it up the way it is supposed to be.
  • 8 years later...
    • By killerklown
      What is the blue wire at taillight?
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By exalrod
      Hello All !
      Could anyone help with this?
