I just got another head. I had it running like a charm. It was idling then I heard a LOUD PING then it died. I forgot to tighten the timing sprocket cam bolt. The pin came out and it broke the end of the cam. I replaced the cam put the head back on. No compression. I took it back off to find the intake valve got bent. Had that replaced. Put it back together and running. I had to take the metal from the cam out of the motor. I took the cover off and retrieved the metal pieces. NOW my reverse no longer works. It almost seems electrical. I don't think I moved or touched anything when i took the metal out of the motor????:aargh:
Thank you! Could this be mechanical and not electrical? It sems more electrical because as soon as I start to move it into reverse it dies like I shut off the quad.??? It used to work before I replaced the head and pulled out the metal from the broken cam.
Thanks for everything.
Sounds electrical to me, could have something to do with the rev limiter malfuntioning, or it could be a switch like Ajmboy said. Check the wiring too, you could have damaged the insulation on a wire and you may have a short somewhere.
Your Reverse switch (located on the reverse hand shifter ) is bad or disconnected. i.ve fixed lots of these.This happens to many ,many warriors.Try disconnecting the wires coming from the reverse switch (l/h lower side)and the wire coming from the reverse lever switch (r/h upper) and grounding them to the frame. this will ensure the start cut out relay is working or just put the relay in your hand and feel it activate as the motor is cranking.
Edited by racers
more
Great information. :yes:
    • By jhamrick75
    • By gbanker
