DUDE
IF IT IS A KLF250 A1
GOES LIKE THIS
(A BIT MESSY, BUT SECOND NUMBERS ARE FOR KLF250A2)
Throttle Case and Cable
Throttle Lever Free Play 2 ∼ 3 mm (0.08 ∼ 0.12 in.) – – –
Carburetor
Make/Type MIKUNI VM24SS – (A BIT MESSY, BUT SECOND NUMBERS ARE FOR KLF250A2)
Main Jet #115 #120 – – –
Main Air Jet 1.0 1.8 – – –
Needle Jet O-6M O-2M – – –
Jet Needle 5GN64-1 5GN74-1 – – –
Pilot Jet #30 #22.5 – – –
Pilot Air Jet 1.3 1.0 – – –
Pilot Screw 1 1/2 turns out 2 1/2 turns out – – –
Starter Jet #45 – – –
Idle Speed 1 300 ∼ 1 400 r/min (rpm) – – –
Service Fuel Level 5 ± 1 mm (0.20 ± 0.04 in.) – – –
below bottom edge of
carburetor body
Float Height 22.6 ± 2 mm (0.89 ± 0.04 in.)
DOESN'T SAY WHAT NEEDLE POSITION, BUT USUALLY 3rd, (MIDDLE)
HAVE FUN
    • By Mhatayas
    • By Kawasakibayounospark
    • By neilroy87
    • By DPDISXR4Ti
      Thanks...
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
