I have this 97 warrior that was running and just died, no compression, I pulled it apart and the exhaust valve isnt closing all the way, It appears the rocker arm isnt coming back all the way, preventing the valve from closing. It doesnt seem to be a problem with the cam. I put a light in the head and at top center I can move the cam between the valves like it should. The rocker arm just seems to stop short of coming back, leaving pressure on the valve spring. I am unable to see what is stopping the rocker arm. It does not appear to be the cam.??????
Any thoughts???????
I just got another head. I had it running like a charm. It was idling then I heard a LOUD PING then it died. I forgot to tighten the timing sprocket cam bolt. The pin came out and it broke the end of the cam. I replaced the cam put the head back on. No compression. I took it back off to find the intake valve got bent. Had that replaced. Put it back together and running. I had to take the metal from the cam out of the motor. I took the cover off and retrieved the metal pieces.
Edited by DirtDemon
Removed content because a new thread was started witht he same question.
I removed some of the content of post #4 because the author started a new thread with the same question. I also removed content from post #5 because it pertained to the info that I removed from #4.
    • By jhamrick75
