By Randel1
By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By KW900A
Hey all, new member, I just joined here hoping I can find some help, I’m always happy to help others but this time I’m at a complete loss. I’ll try to explain all this as best I can.
I got this 94 220 Bayou doing some trading, the guy said it had quit running, and they couldn’t figure out what was up so he robbed some parts for another one and this one just sat in his shed. So it has not run in years. It was missing the flywheel rotor with the ring gear. I replaced the stator. The factory pickup ohms out to spec, generates ac current (.6 vac), I have an Amazon and a used oem cdi, the original oem smoked when I hooked up the battery, safety relay and starter relay are new. Neutral safety is working. It will crank with the button. But nothing I have done will get this this to excite the coil. I have an oem and Amazon coil. Neither really ohm within the spec but I’m tired of thinking I’ve found the problem and buying another part, so I’ve just been checking for a pulse at the green wire to the coil. I’ve ohmed the wires, checked voltages, used jumpers to get grounds, and I can’t seem to come up with anything. I have been doing electrical troubleshooting for years but this thing has worn my brain out. I cannot figure out what I am missing. Sorry I know this is long winded but I have spent hours with this and am just about at a loss, I’m sure it’ll be simple but I’m at my wits end… thanks in advance
