I think it would take more than cams to make a 400ex keep up with any 450. But, it is a good start and like Bot said, it won't hurt reliability much, as long as you don't go with a cam with a really aggressive profile. If you aren't doing a bunch of other mods to go with it, you don't really want really aggressive cams anyway.
BTW, I changed the thread title.
Edited by DirtDemon
a stage 1 or stage 2 cam will not hurt ... but if you go with any thing larger then it will ! i run an XR 400 cam in 1 of mine and it was a big difference .. the dirt bike cam is a little more than a stage 1 cam for the 400ex .. but is a little less than a stage 2 ... its kind of in the middle ... and it is a stock honda cam and is legal to run in any stock 400 class ... i run a few hill climbs that the motor must remain stock... so its legal but its kind of not ...lol... if ya want to know any more about the 400ex send me a message ... i own 2 of the 400 ex's and have 9 motors that i use for different races and or classes that i run...
Keep in mind, when you start changing the gearing, you will sacrifice top end speed for low end performance and vice versa. Changing the front sprocket will make more significant differences, maybe more than you are looking for. Changing the rear sprocket will make a more subtle change, adding or removing teeth on the rear sprocket has the opposite effect of changes made to the front sprocket. If you don't want to loose top speed, then look to motor mods to get the low-end boost you are looking for. It sounds like the XR cam will do well for you, CK1999 seems to know that machine inside and out. If you don't mind losing a couple mph, then a sprocket change is an easy, low cost way to get the low end perfomance you want.
Edited by DirtDemon
I checked a Honda parts fiche and it looks like the camshaft part# was the same in all years. So I would just get the newest one you can find if you buy a used one. If you buy a new one, the year won't matter because they are all the same.
i also have the 07 motor and my cam is an 98 xr400 ... if you really want your 400 to come alive buy a complete xr400 motor and put the internals from it in your ex block and use the xr side cases and have kick start ... it will rev alot faster and be nasty ... but it dosent have the rotating weight of the ex motor and will stall alot easyer ... but it will keep up with any stock 450R hondas and is leagal in most all compitions for the 400 class ...
does bigger cams effect the relableity of his 400ex and will it keep up wit 450
no they dont if you match them with ur motor if you run stock highcompression pistion go with a stage 2 hot cam but you must remove the compression release. i have a 400/ex 460 big bore mil crank stroker with a stage 3 but i can go to webb stage 5 using 114 octane this big can be seen o this web site.
  • 9 months later...
Really? I want more of a lop in my cam really. If I put a Stage 2 Web Cam will it give it more of that?
You need additional parts to run their level 2...
Performance profile designed to increase overall performance. Requires Performance Valve Spring Kit, Shortened Valve Guides, High Compression Piston, Exhaust System, and Hardwelded Rockers.
Oh yeah, Hot Cams is the camshaft company for the average/rec rider. The cam the everyday guy buys. Web cams is what people who build their motors run. That is what Dasa puts in their motors. That is what the pros like Joe Byrd and all the use. My racing buddy who has a 62 RWHP on a TRX450 built by Dasa uses the level 2 from Web. I run a Hot Cams and love it.
    • By Trent Finnessey
    • By Dumass
    • By k9_bones
      Hello, been lurking for a while fixing some of my problems after reading others unfortunate issues. However I can’t find the answers I need. Back story I have a 03 Kodiak 450. A coworker was going to take it to the dump, he said it wouldn’t run. Some mice got in there while it was stored for a few years and chewed up the wire harness. All the wheels were locked up and he didnt want to mess with it. Not knowing if it would run, for a week or so I spliced most of the wires back together. Replaced all the brake calipers and rear brake cable and rebuilt the carb. So far I have put 30ish miles on the bike and seems to run decently. Now my questions. When I put it in gear and the display light showed it is in gear I have to bump the throttle to make it actually go into drive or reverse. It doesn’t slam In gear but kind acts if you let the clutch out to fast on a manual. Is that normal, seems it’s thinking about going In gear then it goes after tapping the throttle. 2nd question, when I use the diff. Lock it acts like it is in a limp mode just by accelerating the lest little bit. It starts to sputter and won’t allow it to have any power. It only does this with the diff lock on. 3rd. The display is stuck on KMH. How do I change it to MPH. I followed all the steps I saw on YouTube with no luck. When I got power to the display it was in MPH but it switched its self and now I can’t get it back. Next are the rear u-joint the same as the front u-joints. I have sprung a oil leak from the rear diff at the drive shaft and need to replace the seal. Sorry for the long post and thanks in advance for any help. I’m sure I will find more things in the future.
