By BuckBilly
By Spritee1
having an issue with the unit when running under a load up a hill or in high gear, seems like the belt is slipping, there is a clapping sound coming from the primary clutch like it releases and snaps back in. i don't think I should have a noise like that. this is a friends unit and he has already replaced the primary twice with the same result.
not sure where to look next
By hardcastle
By Whiterabbit
3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks! I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
By p5200
