By Admin
Looking for Arctic Cat ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Arctic Cat ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Arctic Cat ATV manufacturer, however there are plenty of aftermarket Arctic Cat ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
CARFAX https://www.carfax.com
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
By Frank Angerano
I’m looking for any member that may be familiar with the neutral safety switch on this bike.
I picked up a bayou 220 that I found sitting in a shed. Nice looking bike the guy said it would not start one day and put it away and never touched it again.
So it turns out the neutral safety switch is bad. I jumped it out and the bike fired up and runs good.
I’m more then capable of the work in changing it but this thing is buried pretty good. I’m curious if anyone has done the switch replacement before?
I attached some pics to see.
picture 1 is the side view you can see the green and red wires going into the cover.
Pic 2 shows looking down on the drive shaft coming out of that cover. That is not a simple cover you just pull off.
Im wondering how deep and how much sh** has to come off like the drive shaft etc for this switch to be replaced.
So if any of the QC members have done this switch I’m looking for any input with regard to changing it.
Thanks.
By killerklown
I received an additional parts engine with a 220 Bayou I purchased, but I believe it's a couple years newer than the ATV, Is there a way to decode the engine serial number like we can with VIN numbers?
By Admin
