went riding the other day. All went well loaded atv on trailor and when i got home it would not pull ,foreward or reverse...Had clutches replaced and same thing is happing need help. I just dont know what it could be...
oil the chain for starters.
if that's OK then adjust the clutch.
we once had a 400ex in the shop and the chain was so tight and dry that we had to pick it up with a forklift to move it! chains tighten up as they dry out.
should be lubed every time you ride it.
    • By Gunny
      Hope you enjoy the video ....
    • By Panupong Pradchaphet
