I bought my wife an 07 450 KingQuad two years ago for her birthday. This year I bought an 07 Polaris Sportsman 500 HO from a buddy who did not ride any more. It was neat to test these two head to head. I thought I would post my findings as well as the feelings from seveal other folks who rode both back to back.
First, at time of this comparison the Suzuki had apx. 140 hours, the Polaris had 19. Some might say that the Polaris was not broke in yet, but my buddy rides them hard and I am sure abused it some, so I know the rings were seated and the motor loosened up.
So here goes. Please remember these are mine and my wifes feeling mostly with other members of my family thrown in. Yours may differ.
The Polaris has a MUCH softer ride then the Suzuki. This is good and bad. On flat hard ground the Suzuki will out handle the Polaris hands down. The Suzuki feels like a sport quad and the Polaris like you are floating with poor feed back from steering input. The Suzuki Corners sharp and crisp, the Polaris seems to plow through the corners.
On hard take offs and stops the Polaris really has a lot of body role from suspension movement. The Suzuki not near as much.
In a drag race, the Suzuki is faster at least up to 40mph. This was tested severl times with different riders and the results were always the same. The Polaris was not left in the dust, just beat by 1 or 2 quad lengths. At idel the Polaris is smoother. Both quads were smooth throughout the rest of the throttle range. The Polaris is louder than the Suzuki both in exaust and engine noise. The Suzuki has a louder clutch noise. This may be due to the quieter engine so the clutch can be heard better. Let me add that both quads are fuel injected.
The Suzuki instruments are electronic and the Polaris has a standard Speedo. The Polaris is easier to toggel through several different guages like tach, odo, hour meter. This all done by way of the reverse over-ride button. The Suzuki has two buttons for trip on the speedo face with no tach avaluable. I give the edge to the Polaris in the instrument department.
The gear shifter is easier to use on the Suzuki as it is very easy to shift with your left hand. The Polaris is harder and done with the right hand. The Suzuki does not have the Park function the Polaris has and you must lock the right hand brake on for a barking brake. Both quads have HI, Low, Neutral, Reverse.
Now the brakes. The Suzuki uses two hand levers and one foot pedal. The left hand and right foot pedal operate the rear and the right hand operates the front. Polaris uses the left hand to operate all brakes. The first time I needed to panic stop, I almost went into the trees on the Suzuki. The Suzuki has an enclosed rear brake that is inside the axel housing. Sounds like a great idea but I have never had a problem with open disks like the Polaris. The Polaris will stop on a dime. For me the Polaris wins the brake contest hands down. Another note is that the Suzuki comes with ADC standard. Polaris only offers it on the Deluxe Sportsman.
Ergos are similar with the Polaris having slightly taller handle bars. Both seats are all day comphy. The Polaris has flat foot boards while the Suzuki has raised foot pegs. I would imagion you get better grip with the Suzuki, but the Polaris is more comfortable and I have never slipped even in thick mud on the Polaris. Both bodies seem similar in with in the seating area. To me, too close to call for a better or worse.
Storage is mixed as well. The Polaris has the front storage under the rack and a bigger rear center compartment. The Suzuki has a dry storage bin in the right front fender but is is on the small side. The rear compartment is big enough for most things we carry. Polaris wins this area.
Factory tires on the Polaris are larger and have deeper lugs. Suzuki seems to still do fine in the mud and loose stuff. Ground clearance is similar. Also both quads have 4 wheel independent suspension.
Now for some real world experiance on the trails. Most of the trails we ride are deep wods with some pipe lines thrown in. We don't race and really just enjoy the ride. The Suzuki is by far on the Sport side of Sport Utility abd the Polaris is on the Utility side. In the woods, the Polaris is like a Cadilac, the Suzuki like a Camaro. All depends what you want out of a quad. I would not trade my Polaris for the Suzuki because of the smooth ride and great brakes. My wife likes the Suzuki and the ADC gives her much more confidense going down hills. If I rode high speed trails, I might go for the Suzuki because of the stiffer suspension and better handeling. The rougher the trail gets, the more the Polaris seems to shine.
These are both fine machines and you can't go wrong with either of them. Again your opions may differ, these are mine.
I don't know if I would like all the brakes being controlled by one lever or not. It seems simpler, but when going up or down steep hills, I like to have the option of using one or the other. There is alot of good info there. I am going to move this thread into the This vs that forum. I also added the manufacturers' names to the title.
Edited by DirtDemon
As time goes by, I will add a few other things. One thing I did not mention is that the Polaris does have a rear brake only pedal on the right side. The hand brake controls them all and the pedal only the rear. Other facts to come soon.
  • 2 years later...
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Trent Finnessey
    • By oxidized_black
