Since motorcylcles and atv's don't use a pcv valve to vent crankcase pressure, there is just a straight ventline that goes into the air box, so a little bit of oil in the air box is somewhat normal, if you over fill the oil it will make it a bit worse. Worn rings or valve guides will pressurize the crankcase more than usuall and you will get an abnormal amount of oil in the airbox. If you have tipped the machine over, that could cause oil to run straight through the vent hose. Please post the year make and model of the machine you are talking about.
Edited by DirtDemon
Did you change the oil recently?
When filling the oil you should check the repair manual for the correct amount of oil. The AC oil change kit provides enough oil for an oil change but not the exact amount. If you add all the oil you will have overfilled it.
Finally some engines check the oil level with the dipstick screwed into the engine and some with it resting above on the threads. If you think this may be the problem I can find the specifics for your model. Let me know.
