By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By Snick
^PINOUT:
5 6
2 4
1 3
By Ejwill
By Chucksta
Any ideas?
By tryn2hrd
I have a rancher 420 TM that since i bought it has a cold hard shift problem beyond a doubt clutch is not releasing by shift lever. After it gets good and hot it shifts ok. Tried preloading adjustment screw clutch releases and shifts smooth but slips. Have had the clutch out and apart twice for inspection and didnt see anything wrong. Any tips will be appreciated. I've ran out of things to try instead of throwing new parts at it.
