Storm Damage to trees and Bushes can often be repaired with duct tape. Duct tape the Damaged branch back into place and it will regraft itself. While it secures the limb in place, duct tape also keeps bugs and infection out ot the wound....Of course,,,,If you cover your trees entirely with duct tape from the start, they will be virtually indestructible to begin with!!
Attach Strips of duct tape ( each abut 4 feet long) to every blade of a Ceiling fan and turn the fan on "High". the Twirling duct tape will suck all the yucky cigar smoke, dead fish smell, and other bad odors onto its super-sticky side as it buffs-n-polishes the air clean with its smooth side:yes:
Cover your cuts and Bruises with as many layers of duct tape as needed to stop the Bleeding....Or,,,Use duct tape to secure towels, shirts, blankets, or other forms of compresses on those really nasty wounds.....
I can just imagine trying to pull duct tape off of a cut...:confused:
If you can afford a large childs wagon and four cordless drills, you can afford and electric car!!!
Remove wagon wheels
Replace axles with large Screws
Place screw heads into drill chucks
Duct Tape drills to bottom of wagon so wheels are back in place
turn on drills and drive!!!!!!!!
  • 8 months later...
  • 5 months later...
Duct tape also works for getting rid of warts (no joke) place sticky side on warts for 1-2 weeks and the wart will no longer be there. Supposedly something in the glue gets rid of them.
We should write a book on home remendies. :wink::yes:
Not to sure about that one Bio. I can only imagine the cure for diahreha with duct tape.
-Place duct tapes in general area of butt hole and tape cheeks together. For more detail see butt hair removal section 2-B.:laugh:
:laugh:
    • By alexwv1863
      I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
    • By DGBear
      This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
    • By JGou
      Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage  1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
      Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx,  Jay
    • By anryu451
      Rescued this thing from sitting in a warehouse the last two decades. Finally got it to fire, but when I put it into neutral to do so its now stuck in neutral, and wont shift no matter how much pushing, rocking, etc. Even with throttle it wont. Range lever on left side will go from H to L, but not to R, and this makes no difference on it being stuck in neutral.
      Any suggestions?
