welcome to QuadCrazy. The problem you have would be that your shift linkage needs to be adjusted if it goes into low and reverse your problem would most like be that it is pretty simple to fix. When you try putting it in high gear does it sound like the gears are grinding a little? Check the oil level two in the transmission case
    • By Randomnumber73
    • By Sportsman500guy
    • By DZL1
      Question for you guys. I have a 98 bayou 220 that I picked up cheap cause it's wasn't running. So it's has very low compression. It is getting spark and fuel.
      What should my next course of action be? Any other tests I should perform or where to start looking?
      Thanks in advance.
