Upon arriving home, a husband was met at the door by his sobbing wife.
Tearfully, she explained, 'It's the druggist. He insulted me terribly this morning on the phone.
I had to call multiple times before he would even answer the phone.'
Immediately, the husband drove down town to confront the druggist and demand an apology.
Before he could say more than a word or two, the druggist told him, 'Now, just a minute, listen to my side of it.
This morning, the alarm failed to go off, so I was late getting up.
I went without breakfast and hurried out to the car,
just to realize that I'd locked the house with both house and car keys inside and had to break a window to get my keys.
Then, driving a little too fast, I got a speeding ticket.
Later, when I was about three blocks from the store, I had a flat tire.
When I finally got to the store, a bunch of people were waiting for me to open up.
I got the store opened and started waiting on these people.'
'All the time, the darn phone was ringing off the hook.'
He continued,
'Then, I had to break a roll of nickels against the cash register drawer to make change, and they spilled all over the floor.
I had to get down on my hands and knees to pick up the nickels, and the phone was still ringing.
When I came up I cracked my head on the open cash drawer,
which made me stagger back against a showcase with a bunch of perfume bottles on it.
Half of them hit the floor and broke.'
'Meanwhile, the phone is still ringing with no let up,
and I finally got back to answer it.
It was your wife. She wanted to know how to use a rectal thermometer.
And believe me mister, as God is my witness, all I did was tell her.
    • By Chucksta
      Any ideas?
    • By drag_on
      after the gully wash i dont know if its such a good idea to go
    • By gatorschevy
      I own a few older quads mix of kinds a couple of  Yamahas, a Honda, can-am  a Kawasaki, they are older quads but in good shape the question of the day is....... what's the best way to polish up the plastic?
    • By remnar
      New member here,
      I have searched here and other places and have not found an answer to my problem.   As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
      I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC.  I shows a 8-1 which is a TPS error.  This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v.  It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light.  However, there are no PS codes of that value.   This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
      A couple questions.  First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
      Second, anyone used a OBDII reader with an a 4pin adapter to pull codes?  If so, what system do you use?
      Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
