I have two 2006 Kingquads and use them almost every day to get around the ranch.
I just replaced the clutch and front brakes on one of them and while it was down for about a month it started running rough and the gas smelled funny.
I added some Seafoam to the gas tank, air intake and crankcase and it started burning oil with a blue smoke and goint through about 1/2 quart of oil per tank of gas.
I have done compression check and leak down test and both are good.
I have drained and cleaned gas tank and changed oil twice.
Don't want to take the top end off or replace rings when the compression and leak down don't indicate any problems but the blue smoke is so bad I can't ride behind the oil burner.
Any Ideas?
Drain that engine oil and replace it with 4 stroke atv oil. Sea Foam or any other cleaner when added to a crankase will think out the motor oil. If I had to guess, your oil is slipping into the combustion chamber.
My first step would be an oil change with a new filter. See if that helps.
Hello.
I agree with getting rid of the sea foam oil additive.
Given that you have got smoke comming out of the motor and burning lots of oil, you are due at a minimum a set of rings and maybe a piston and barel!
what was the compression amount? do you remember what it was (also if it was hot or cold)
because if you are burning oil, it can normaly only comes from 1 place (the sump) and can only get there from the via 3 ways.
1 pass the oil and compression rings
2 oil blowing out of the engine crank case breather and getting injested by the engine as it breaths air (note: air box will have oil in it everywhere)
3 flowing past the Valve stem seals and running down the Valves in to the combustion chamber.
then there is the long shot idea of maybe you have a crack in your piston, or a broken section under the top compression ring (like I found in a Honda TRX400ES last month) and oil was working from under the piston, behind the top compression ring where it then had direct access to the combustion chamber... The bike started great, sounded great, but would not idle! but only blew smoke with high revs.
The problem was caused by the compression at Idle was blowing passed the top ring, down in to the crankcase and putting air pressure in to the crankcase, then venting in to the airbox where it was blowing a mist of air and oil on to the air filter (then back in to the motor and stall the motor after about 15 seconds)
anyway, it would seem that off fuel may have been your initial problem because it was stored for a month. but then the sea foam has changed the lubrication propertys of your oil and hurt your rings and maybe your barel.
If you do chose to pull down the motor and check the piston and rings. Do take out the exhaust vales and clean the valve seats and top side of the exhaust valves, because they will by now be very dirty and not seating properly.
it will be no good pulling it down and not having it working properly after some new rings.
    • By Coyote251
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Gunny
      Hope you enjoy the video ....
