Oh god. I miss it, 94 Built/street Camaro for built quad.
I miss it already and it hasnt been a year..
I have a 1994 Camaro z28, LT1 v8 Color is red I'll email pictures upon request @ [email protected]
Modsthe good)
Subframe connectors
cold air intake
58mm BBK edelbrock throttle body
edelbrock headers
flow master exhaust (sounds mean with the headers)
lowered 2 inches in front
ported and polished intake
motor rebuilt 40k ago
trans rebuilt 1k ago with shift kit and hardened shafts.(for nitrous)
motor is internally sound and hardened internals for 250 shot of nitrous!(wooo juice)
Has new 3.73 gears on 10 bolt solid rear end.(posi)
has new nitto drag radials with under 10 passes on the 1/4th
Has kelley steel belts up front
Weld Drag lite wheels rear are 8X15! AND FRONT ARE 5X15 SKINNY FRONTS!
Overall car looks pretty good for being an older car. paint has a few scratches and dings and i have a NEW front bumper for it, but it will need painted.
oh and has a 1800-2000RPM torque converter.
the bad..
Interior needs help, but not much, headliner is sagging,(pinned up)
Dash has a crack and driver seat has a rip, this is all pretty common stuff so no suprises there.
needs the turn signal switch its like 20 bucks? maybe less idk brights wont kick on and left turn will get stuck on. thats about it.
I maybe have misses some stuff but overall car is awesome and very fast.
again email me with any questions or trade offers, looking for another car? maybe quad. have cash if yours isnt worth as much as im asking (4500) fair price i assume maybe a quad+ flat screen tv. or something along the lines, thanks!
miss you guys!:):mad:
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By utvboard
      2009 HONDA BIG RED
      Big Red
      KEY FEATURES
      2009 Honda Big Red in Camo
