King, UTV shocks, have now reached a new level of versatility and performance. They've taken the knowledge gained in their successful bid to win the Baja 1000 and domination of short course racing and used it to make a great shock even better. King UTV shocks with the Wide Range Compression Adjuster give you the ability to precisely adjust compression damping from super soft to super firm with
More...
    • By leecon
    • By KSIM
    • By KSIM
      View File CFMOTO CFORCE 1000 CF1000AU/CF1000ATR service manual
      cforce_1000_2018.pdf
      Submitter KSIM Submitted 03/08/2025 Category CFMOTO ATV
    • By nberga
      Hi,
      This weekend went on a trip with my all brand new cforce 1000 touring, went from tarmac to reach the small muddy places and dirt and even sand.
      Was running great until tre situations occurred:
      First, after putting 50km without problems and still respecting the break in on the engine, we came across a sand small uphill and just turned the 4x4, and almost reaching the top, got a strange loss of traction with a noise like something was slipping, the noise looked to came from the front but cannot give 100% sure it was the differential or not, but something was definitely slipping, also i disconnected the 4x4 and tried to make the uphill only rear traction and almost reaching the top the same noise. I got a friend that was on my old 850XC and it drove pass this small uphill almost at idle.....what do you think??? Belt Slipping, Front differential or Gearbox/CVT?
      Second, after this situation, i had the engine light going from on to off on the trail back home, but on the trail back home, i had no issues with temp rising nor noises nor anything, we drove normally, but without sand nor uphills, just rolling normally on dirt roads.
      Third, a strange situation, riding on normal mode, i was going at 38 to 40km rolling but the engine was revving on 4000rpm at those speeds, i feel that it was a little bit more reavs than usual for that speed, but this is my perception, what do you think on this???
