I have spark i have gas i have air. i have weak compression head looks good piston looks good,i am wondering if the rings were to be stuck i could clean them and reassemble ?
I wouldn't bother, you can get a new piston and rings, and put a fresh bore on the cylinder for around $200 maybe less. If you have to take it apart, you might as well make sure you don't have to it again for a while.
Warren, how did you make out with this? What year is this atv?
    • By Kawasakibayounospark
    • By carkivey3
    • By DZL1
      Thanks in advance.
    • By pastorjeep
      Need some feedback here. I picked this machine up with PO saying no spark. I have tried new stator, CDI, and coil. The stator ohms 231 w/r to w/g and .1 red to blue. The coil is .8 primary and 2.53 secondary. I have 12 to the CDI with ign on and the wires from stator to CDI have good continuity. This model only has 12v on or off for ign/kill source. Still no spark?
