      QUADCRAZY NEEDS YOU!
    • By DayBreakJim
      20230725_171507.mp4
    • By trootncsse
      another new guy.  have a Yamaha Kodiak 700 and Polaris 500HO. My brother has a couple of Polaris. Summer in northern Michigan and ride some in Michigans UP where we have a cabin in backwoods. New to quads last year as far as owning one. Have been a jeeper for many years and modified/built several so have some mechanical ability, pretty knowledgable electrically too. Initially started reading the forums to find out what others using for lubes and common issues, other maintenance etc.  Hopefully I can contribute.
    • By thelostjs
      A new series by mike sabo called top quad 3 and sxs blog has a recent series called cheap quad challenge. both have taught me a lot about how fun and affordable offroading in smaller machines can be..
      I just bought a cheap LAKOTA and i'm in the process of getting it trail ready i cant wait!
      Let me know if anyone has seen this and what thoughts you've had. it was a incredibly helpful thing for me as i didnt know the lakota existed until i saw the show!
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
