      QUADCRAZY NEEDS YOU!
    • By Skindian82
      Won't cold start if I do get started with starter fluid won't start again later when cools down
    • By BCNemo
      I have a 2001 Yamaha Kodiak 400 (YFM400FWAN©) On a recent hunting trip a problem popped up and I hope someone else has experienced this, so that I can learn from them instead of going on my own hunt for an answer.
      The Problem:
      On cold days (sub 25 degree) I choke the Kodiak and it starts instantly. It revs up and runs on "high idle" without any problem. However when I return the choke lever to its "normal" position the ATV continues to run and a very high idle. I cant put it into gear until the idle comes down, which it doesn't. In order to use the bike I have to shut it off and when I restart it I must place it into gear before the engine gets a chance to rev up. It then returns to a normal idle and the machine behaves normally. This only happens on real cold days but it is a problem I want to fix. Can anyone offer some help?
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
