      QUADCRAZY NEEDS YOU!
    • By Joeguy
      So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
      Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
      The first round of racing for the AMA Pro ATV and Pro Sport racers in the 2023 ATV Motocross National Championship (ATVMX), an AMA National Championship, was greeted with warm sunshine as the season kicked off in grand style within the high banks of the Daytona International Speedway. View the full article
