By quadcrazy
QUADCRAZY NEEDS YOU!
By DayBreakJim
20230725_171507.mp4
By Fishy09
Hi folks I have been registered on the forum since 2012 & enjoy reading the mechanical issues and advice given to remedy them, I have not received the weekly newsletter since Feb 12 & just wondered if I had not been included due to lack of posts or input, there has been no change of email address or forum settings change from my side and miss my weekly fix following the current issues folks are having, looking forward to being added to mailing list again 👍.
Cheers.... Fishy
By Ulfthednar
The Dog loves the runs.
https://youtu.be/tKjBFuHCkM0
By Bdubb0227
Hey guys, I'm new on here but I have a hell of a problem. I traded for a 98 timberwolf 2x4 and it ran good but smoked. So I decided to get piston and rings with new jug a and put everything together did the timing by the marks on the fly wheel and the cam gear and now all its is rolling over in the back fires extremely loud someone please help
