This video was submitted to the by GrizzlyRider.
Description of Video: Who knew the mythical creatures could be found in the hot AZ desert? Part 1 of this story has the bizarre report. Part 2 has the sights and sounds of Sasquatch! Both from KTVK in Phoenix.
Video Tags: bigfoot arizoma
      This past weekend the 2025 ATV Motocross National Championship Series (ATVMX), an AMA National Championship, held its third round of AMA Pro ATV racing, and its first amateur round of racing at Echeconnee MX in Lizella, Georgia. View the full article
    • By heath
    • By jmeier1981
      Ok so I bought the 05 brute force and after putting about 60miles on it I have some concerns.
      The engine seems to run REALLY HOT, like almost burnning my legs through my jeans hot but no warning light comes on and it doesnt seem to "act" hot is this normal, does it have any saftey feature to prevent over heating or heat damage?
      It also seems to have a slight miss, or hesitation? When you slightly crack the throttle open and hold it at a steady RPM to give it a slightly higher idle it will run smooth for a couple seconds then miss and sometimes backfires. It also seems to sometimes have a hesitation if you jump on the throttle, what could cause this?
      Also a couple times when shifting from reverse to high it sounded like it got hung up in between and there was a slight squeal as if maybe the belt was slipping and there was also a slight burning plastic of rubber smell. The belt IS new and it doesnt feel as if it is slipping when accelerating and the belt light hasnt come on.
      Anyone have any suggestions?
      It does seem to run really well and HARD accept for the slight hesitation or cough and the occasional backfire, I ran it up to 69MPH with both me and a buddy of mine on it, combined weight of almost 500lbs
      Loretta Lynn’s Ranch would be the closing scene of a story started in early March with the 2024 ATV Motocross National Championship Series, an AMA National Championship.View the full article
    • By Brian Emerson
      Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
      Thanks and regards,
      Brian
