    • By dalton7545
      QUADCRAZY NEEDS YOU!
    • By andyt
      I have a 1993 Polaris Trail Boss 350L 2- stroke.  after about 200 yards or so of driving the motor boggs down.....it will stay idling but if I floor it, it will die.....if I turn it off and wait a few minutes I can turn it back on and go like hell for another  couple hundred yards.... I thought the pilot might be worn out(I have it nearly closed now)......maybe the choke plunger isn't sealing or the Bowl isn't filling quick enough.....any suggestions would be appreciated.
    • By gt2003
      Changed oil and filter today.  Took it for a ride and it seemed to bog down or hesitate when i gave it gas.  Fresh gas too.  Any ideas?  I’ve had this machine since it was new.  Had carb rebuilt last year.  It runs great besides this.  I’m leaning towards maybe an exhaust issue but honestly, i’m not an engine guy so I’m just guessing.  It’s nothing major, it would serve my needs the way it is but there is obviously something a bit off.  Where should i start?
    • By DayBreakJim
      20230725_171507.mp4
