Owned the Ozark for 7 years before it let me down. Wheel bearings went out. Pretty impressive since it is a bulldozzer / puller / joy rig. Pretty reliable if you ask me.
Is that the Ozark in your profile pic? If it is, that is pretty good considering you submerge it in water and all...:biggrin:
It's the same one from my profile pic . Only stream cross once in a blue moon or two. I change all oils 3 times a year. Rear end oil is pretty cheap to change.
I hope so to! I pretty impressed with the Ozark's reliability.
That is very reliable. You should write a review on it!! As a matter of fact..we should have an atv review section!!
    • By dalton7545
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
      It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
      I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
    • By kiriyaaoi
    • By mga
      I have to replace all 4, how much is involved?  Will they slide out of the front yoke? Or, do the boots just slide over the wheel end?
