POTM Poll
5 members have voted
  1. 1. POTM Poll
    • micorps
      0
    • mywifeknowseverythin
      2
    • Tony
      0
    • Sahlberg
      1
    • okierrider
      2
    • By qcm413
      Hi,
      thank in advance
    • By cameronokeefe6
      I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
      I was thinking on getting a 200x piston, will this work and give a good power increase ?  I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
      I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
      If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
    • By heath
    • By Gordo7799
      I am looking to replace the Maxxis AT 25x8-12 tires on my Yamaha Grizzly 700 and put on snows.  Going bigger to 27" and wider to 9" or 10" is probably a good idea, yes????? I've heard that Maxxis Zillas are good.
      I just want to use the quad on the trail to get into the lake and then go ice fishing.
      Appreciate any and all advice.
      Thank you!
