HI everyone. I ride a raptor 660 2004. I just had a new clutch installed last summer. I didn't ride much the winter but a few times on the ice and mud. So now its spring and i took it out again but i noticed that the clutch isnt catching very well. I hope the new clutch isn't gone, but don't you need to adjust your clutch as you break in your new clutch? Any help would be appreciated thanks!
You should adjust the cable to reduce free play. There should be a minor adjustment at the lever on the handlebars. If you need a major adjustment, I believe further down the cable there is a an ajustment with lock nuts.
Exactly what AJMBOY said. Have you been able to adjust it?
    • By JMSwed
      Hi EVERYONE
      New member here
    • By qcm413
      Hi,
      thank in advance
    • By mmikesell
