I think I just found my new Jobs
By Ajmboy
So we are almost a month into winter and I've been so busy working on my house that up until today, I didn't realize that we just haven;t gotten any real snow yet to warrant putting the plow on my grizzly. So that got me thinking, what are the latest plows out there and what ATV plows are the best? I've got 2 snow plows for my grizzly, a quadboss pile driver atv plow set up and a snowsport ATV plow. They are both a bit dated now and I tend to stick with the snowsport due to ease of use and I just like it so much. So if you have a plow on your ATV, please let us know what it is and post a picture with your atv/plow would be awesome. Would also like to know what you like and dislike about it.
By ATVNetwork
By Gordo7799
I am looking to replace the Maxxis AT 25x8-12 tires on my Yamaha Grizzly 700 and put on snows. Going bigger to 27" and wider to 9" or 10" is probably a good idea, yes????? I've heard that Maxxis Zillas are good.
I just want to use the quad on the trail to get into the lake and then go ice fishing.
Appreciate any and all advice.
Thank you!
By DonB
Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator. Must I spend the $750+ for a new assembly from Arctic Cat?!? Here's what I've tried so far.
Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists. I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly. When I can temporarily get the PSI right, everything works great. Anyone else ever dealt with this problem, and, if so how did you fix it? Perhaps I should adapt the fuel system to include a gas tank return line?
Any insights are greatly appreciated, Don
