I have an 1988 honda trx250r that runs backwards yes the engine runs backwards. replaced everything stater cdi coil wireing harness every thing and when i kick it, it fires and reverses the engine and runs backward im useing a dynatek ignition box to even get fire. when i put an stock new cdi box i get nothing. can someone tell me what is going on?
    • By Trent Finnessey
    • By Dumass
    • By Arizona
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
