I have a 2007 honda rancher 420 with trans problems. When I am riding it with the motor at around half and throttle and up the gear light will start to flash and then go away for about 5 seconds and then a dash will come up where the gear is sapose to be. I have to cut the fourwheeler off and use the front brake to crank it in gear and than wait a few seconds before it will shift. It does it in all gears except reverse as far as I know. It started about 4 months ago and is getting worse everytime i ride it. Please help me figure out how to fix it or atleast what is going on so I can take it to have it fixed.
Unfortunately I do not have any parts diagrams for that, you should really invest in a good manual for that machine.
But try looking on the left side if the machine under the fender. Look for electrical wires to a sensor. Maybe wires are sheered or sensor cracked. Do you have a metal cover over by the starter area?
I know there are sensors under the left fender (looking from the front) I will check them tomorrow when I get off duty thanks for the help i will get back to you.
There is a sensor that is referred to as the angle sensor, which could be your issue. If you are not confident, you should have someone troubleshoot it for you at a shop/dealer.
Once you locate the sensor, look at the condition of the wires, connector, and sensor iteself. Make sure no trail debris hit it.
Look at #10 below:
If it turns out bad, go to Bike Bandit where you can get it for @ $70 Part# 5904359-001
There is a series of long & short flashes you have to count ..
I didn't know that..how do you set it to flash/check? Are you putting it into some sort of flash/diagnostic mode?
  • 11 years later...
I have a 2007 Honda rancher when I drive with a heavy trailer  around it feels like someone is putting on the brakes until I let up off the gas something makes an a mechanical noise on the motor and releases and lets the quad resume for about another 50 feet then starts to slow down and does the same thing drives fine when not towing anything
  • 4 months later...
    • By Trent Finnessey
    • By Tinkeringreg
    • By Dumass
    • By Arizona
