2003 arctic cat 400
moose lift kit (modified for IRS)
highlifter springs
warn 2500lb winch with synthetic rope
raider hand guards
dyno jet
k&n filter
outer wears pre-filter
removed air box lid
26 inch itp mud lites
12 inch itp delta black rims
outlaw EPI purple secondary spring(for clutching)
outlaw EPI orange primary springs (for clutching)
arctic cat front HEAVY DUTY front bumper "the plow"
arctic cat rear bumper
other stuff i'm probably forgetting
  • 5 months later...
as of right now it is other than a k&n filter,and the can,i am going to leave it stock,because as soon as i sell my harley,i am going to get a 700 raptor and trick it out....maybe i will post it on here...lol. Then when i get my 700 , i am going to sell my other raptor...
my 1st ride is a 03 ltz400,95.5bore,+5 crank,P&P,13.7:1, JE piston ,spacer plate,RHC Ferrea +1 intakes valves ,DRZ valve springs ,RHC #187 cams ,DRZ manual decomp ,DID cam chain ,MCCT, no air box ,Sredrum TB 42mm FCR ,RAT stack ,no air box ,WB fuel screw ,EMN needle ,quick shot AP cover ,LTZ 06 clutch TRX450r drive plates w/trx400ex springs, C2HB, ex thumber,04 trx450r air boot, Barker Performance pipe, DRZ flywheel, dynatek adjustable cdi, nerf bars, trx450r shocks, brass steering stembushing ,frame gusseted, nerf bars,+4 swinger ,lowered front & rear ,12 paddle 22X10X8
mods yet to do are; move battey box ,install huge airfilter
best dragrace time 5.427
ride #2 04 V 650 AC dynatek cdi
This suzuki sounds NASTY!!!! Have you had it Dynoed Post Pics of it
  • 4 months later...
Fairly new here so I guess I'll add my list to the thread ... even thou most of the bikes seem to be sport bikes ..... :seeyac:
2011 Camo Outlander 800R MX-XT
Mods I had the dealer do before I picked the bike up ... :fact:
HPG Shocks & Springs
Twin Air air filter
3 mode PS unit (for my tracks)
Terry Cable Twist Throttle
Remove bumpers
Remove handguards
Install BRP Fender Flares
Install shock covers
Mods I've done since the bike came home .... :woot:
Install Bison Front & Rear Bumpers
Modified the Bison Front Bumper
Pro Taper Contour Fat Bars with a "Raptor" bend
PowerMadd Star Series handguards
Removed the Terry Cable Twist Throttle
Installed a Terry Cable Dual Gasser Twist Throttle
ODI Gel grips
Modu-Rak system front & back
Roto-Pak gas paks (2ea 1-gal & 4ea 2-gal)
Removed the BRP Fender Flares
Installed Koplin Defender II Fender Flares
Removed BRP Hitch
Installed TCC Hitch with Custom tow ring
Installed "The Spine" frame stifferner
Ricochet skids
Dual battery setup with an Odyssey PC680 battery
Tamarck Rear Wrap Around Cargo Box
Hayden Adjustable Temp Controller
Runbberdown 2 inch Lift
CVTech Primary Clutch worked by Airdam
STM Tuneable Secondary Clutch
XMR Clutch Cover
Header wrapped the Exhaust
Custom CVT Exhaust Snorkel
Blocked off factory air box intake
EHS Racing Air Box Lid
Removed Warn 3000 lb winch
Installed 3500 Pro Mark Outback Winch
Sold stock tires & wheels
Installed 12 inch ITP T7 Beadlock Wheels with a 4+3 offset
Installed 27X11X12 Intgeco Reptile tires at all four corners
Eagle SNowplow setup
Complast Tatou 4S tracks
There may be some other mods I did ... but I can't remember them right now if I did. :thinking:
Here's a couple photos of it in the garage ....
2007 Arctic Cat 650 H1 4x4 Automatic LE (Marsh Green)
Tires: Trail: Mud Lite XTR 27x9-12 Front and 27x11-12 Rear / Mud: Highlifter Outlaws 29.5x12-12 Front and Rear w/ 1" Spacers.
Tuning: 2" Dual Intake Snorkel, Updated Airbox, Duckbill Mod, Black Magic Slip On, Exhaust Snorkel (Bolt On).
Clutching: /// Airdam Stage 3, EPI Red Spring.
Motor: Speedwerx 700 BBK, Webcam, 11:1 CP Piston, Coolant Overflow Tank Vented Near Pod, Radiator Racked, Cap on Carb Drain.
Suspension: Sway Bar, Hockey Puck Mod, All Balls Wheel Bearings and Tie Rods, EBC Brakes and Rotors.
Electrical: Auto Meter Temp and Volt Gauge, 4" PIAA Lights, Super-Bright Red LED Taillight Bulb, Circuit Breaker for Fan and Main.
Accessories: Custom Graphics by Arctic FX, Hunter Green PowerMadd Star Series Handguards
Herculiner on Racks, Bumpers, Snorkels, and Radiator Mount, D Ring Tow Hook and Strap
Snow: 60-IN. AC Plow Blade - Modified, Remote Angle Control, and Winter Front
2004 TRX450R
Durablue +4 X33 axle
Houser slicast +2.25 a-arms
Houser +1 stem
GTT linkage
Pro taper contour bars
Stock shocks re valved by monster performance
Pro armor tether kill switch
Pro armor swing arm skid
CST ambush tires
PRM grab bar
Tusk nerf bars
Tusk parking brake block off
Hmm I think thats it..
uh were to start
race-2008 KFX450R-FCI; DASA pipe; pro armor FAT PEG nerf bars; Houser anti-vibe steering stem; Razr TTs all-around; RATH front Bumper; RATH sway bar; ROX speed powermadd hand guards; QuadTech Carbon Fiber Air Duct System; Fuel ATV parking brake block off; Hiper Tech3 rims; stage 2 hotcams; ProCom ECU; PCIII; Flexx bars; ODI Rogue grips, ASR A-Arms
on order for the KFX450R-nothing trying to decide to sell it or not:aargh:
trail-2009 KFX700-Trail Tech Vapor, bar clamp; Cycra handshields; ODI Rogue Grips; Leo Vince exhaust; Dynatek FS; AC rear skid; EPI Red; Alba's propeg nerf bars; quad boss front bumper; ASR PRO-X Tie Rods; Speedline'z braided front lines;stage 3 Elka shocks; VFJ primary stage 3 clutch with spider mod and custom spring; and fast flexx bars
I have a muzzy super pro sitting in my garage that I need to put on, but I don't feel like re jetting and I need to adjust my valves. next weekends projects
Edited by Jonny450R
Well, in prep for a week long ATV trip starting Sunday, I took the CVTech primary clutch off my Can-Am and Installed a QSC primary clutch today. :coolgleamAc:
I then took the stock driven off, took off the stock spring & helix & installed a 650 helix & a stiffer spring. This was recommend by QSC for the altitudes I ride ... :cheer2:
And then for Sh*ts & Grins ... I installed a 80mm 60cfm fan in the top of my CVT inlet to push a little more air thru my clutch housing ... or that's the plan anyway ... we'll see if I actually get any real benefit from the fan. :thinking:
Here's some pics of the new clutch ... :woot:
http://s679.photobucket.com/albums/vv152/GunnyE9/QSC%20Clutch/?albumview=slideshow
Edited by Gunny
My mods fat 1\2 bald with custom bifocals gray highlites in my side hair 1 hip larger thanks to my quad & a 3 level fusion in my back. Now for my quad Moose power module & tires redone the racks in textured black & have a set of ITP wheels not installed yet & an invisible front bumper. lol some of you will get the bumper joke I think. The title does say post your mods not your quads mods.lol
QUOTE=hangingon;56584]My mods fat 1\2 bald with custom bifocals gray highlites in my side hair 1 hip larger thanks to my quad & a 3 level fusion in my back
From your wife kickin your as* !!! :laugh:
Nope that hasn't happened yet. Thats when the post will read I'm sorry my husband can't type right now and his feeding tube has a knot in it The doctor said theirs a good chance he will not remember this site or how to turn on the computer.
    • By Trent Finnessey
    • By Dumass
