Houser +2 standard travel a-arms, GT Thunder rear link & re-valve, Houser stem w/ Tag CR bend bar, RPM dominator rear axle,
Holeshot HD's on T-9's
Lets See....
Im just trying to think of what I havent Done:bowl::wacko::wink:
Lets just say it isnt a Trail Rider any more.....
Here is a Picture from around 86 or 87......
346%3B9754%3A%7Ffp64%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E23238%3A495%3B%3A5%3Aot1lsi
Here is what I started with....
Ugly ol RAGGG!!!!
346%3B9754%3A%7Ffp58%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E2323489%3C259%3C4ot1lsi
I then Morphed it into this...
346%3B9754%3A%7Ffp58%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E23234%3B23564%3A9ot1lsi
Then did a Complete Tear down to the Frame and did her right..
346%3B9754%3A%7Ffp64%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E232394462%3B%3B57ot1lsi
346%3B9754%3A%7Ffp47%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E2323%3A9%3B6%3B5598ot1lsi
346%3B9754%3A%7Ffp63%3Dot%3E232%3A%3D%3B%3A4%3D964%3DXROQDF%3E2323%3A9%3B%3A%3A%3C%3B%3B9ot1lsi
346%3B9754%3A%7Ffp343%3Enu%3D3239%3E%3A%3B3%3E873%3EWSNRCG%3D323373%3A274848nu0mrj
Oh,,,,And in the Background in the last picture you will notice an 87 750 Ninja I turned into a 3 Wheeler....Still working on it...I will post the results Real Soon...Brrrraaaaaappppp!!!!!
  • 3 months later...
2000 Yamaha Warrior
Scott Grips
Race Cut Fenders
Dg Bumper
HMF slip on
K&N Proflow clamp on kit w/ outherwares no lid
Dyno Jet
Shockwars
UM SwingArm Plate
Powermadd star Handguards
MSR Pro-Raptor Clutch perch w/ shorty
Tusk Block off plate
Maxxis Razr's Back
Maxxis Razr 2's Front
ITP C-series
and a few other odds and ends
2000 Yamaha Warrior
Scott Grips
Race Cut Fenders
Dg Bumper
HMF slip on
Dyno Jet
Shockwars
UM SwingArm Plate
Maxxis Razr's Back
ITP C-series
Looks like you added more Weight to an Already Heavy Quad....Is She Faster with those Scott Grips???:D
BTW Quadcrazy....I havent been on in a While....Nice Job on the New Digs around here:cool:
29.5 Outlaw tires
3' XPATV Lift
1.5 Wheel Spacers
HL Outlaw Clutch Kit
Snorkeled Clutch and Airbox
Twin Air filter
Kimpex front and rear bumpers
Warn 2.5ci Winch
Custom Stereo (using Extreme Sounds box)
HMF Exhaust (waiting on VDI to be released to install)
C&S Rear Rack
Rear Back Rest
Custom Mudguards
HL Gel grips
and a few other things
85 250r
wiscoe hot rod crank
wiscoe .40 piston/stock comp
cr headgasket
custom head pipe/ sx silencer
boysen rad valve
mikuni 42mm carb
kn direct clamp filter
trx cluth update
vesera clutch stuff
mair black plastic
hondaline front headlight guard
avs clutch lever w/hotstart for carb choke
tag handlebars
recovered seat
custom adjustable suspension link
omf swingarm skid
itp 10x10 rear wheels w 18x11x10 dico fast trackers
dg trx rear grab bar
1989 yami blaster (girlfreinds)
custom painted pink
pink seat cover
pink with white flames shock covers
wiscoe .40over piston
vitos 3mm stroker stuffer crank
removed tors system
oil injection removed (even the gear)
stock headpipe/silencer
rejetted carb
uni filter
fly handle bars
itp 8x8 rear with 18x11x8 dico fast trackers
this thing is a killer woods machine!
85 250r
cr headgasket
boysen rad valve
mikuni 42mm carb
trx cluth update
vesera clutch stuff
mair black plastic
tag handlebars
recovered seat
omf swingarm skid
custom painted pink
pink seat cover
removed tors system
rejetted carb
uni filter
fly handle bars
On my 86 Tri-Z I have the
HONDA WING CLIPPER MODS......
NOTHIN STOCK:D
GIT IT RAGG!!!!!!!
Adjustable Stator Plate, V Force series 2 reeds, DG nerf bars, LSR Anti-vibe Steering Stem and handle bar clamp, ASR +2 A-arms, Pro-racer tie rods, Extended steel braided brake lines, billet brake line clamps, AC font skid and DG rear skid plate, FMF fatties w/ powercore 2 silencers, E-brake block off kit, motion pro throttle/tors removal kit, AC front bumper, +4 LSR axle, LSR sprocket/brake hub, LSR axle locknut, hide-a-key ignition relocator, renthal handlebars, K&N air filter w/ pro design adapter plate, Engine ice coolant, Elka front shocks w/o rezzies, extended billet throttle, FMF boost bottle, All balls axle/bearing kit, Cyrca barkbuster hand guards, Hiper Tech carbon fiber double beadlock wheels, ITP GNCC Front and ITP XCR Rear tires, GPR Steering Dampener (Not on yet).
I wish the damn GPR you get off Back order, i paid for it in August. Love the Hyper Tech rims. The elka shocks are awesome.
Next on the list will be the IMS 5.5gal fuel tank, Elka rear shock, shave the heads, clutch kit, hydraulic clutch, lsr swingarm, Prop peg nerfs.
2006 honda recon 250 2x4
snorkeled exhaust
snorkeled air box
dielectric on spark plug
heated grips
extended breathers
lots of silicone in various places lol
rear 22x11x9 mudlites
painted rims black LOL
a-arm guards
LOTS OF SCRATCHES
a hitch
mile marker 2500 lb. winch
snow plow/trailer/air raider
thats it for now...saving up for a bigger atv ...
2002 400ex
LONESTAR AXEL
LONE STAR SPROCKET HUB
HARDKOR FRONT HUBS
MODDED 400EX FRAME
ASR +3, up +1 PRO STAR A-ARMS
ASR TIE RODS
GALFER STEAL BRAIDED BREAK LINES
TCS REAR SHOCK
KAYABA PIGGY BACK FRONT SHOCKS
DG BUMPER
TUSK NERFS
OMF AIR SCOOPS
LONG HORN 1 1/8 BARS
LONG HORN BAR CLAMP
ITP FRONT RIMS
20"KENDA CLAW FRONT TIRES
CHAMPIAN REAR BEAD LOCK RIMS
18"CARLISLE TURF TAMMER REAR TIRES (SUMMER)
18"GBC SHREADDER REAR TIRES WITH CHAINS (WINTER)
NACS MUD CAPS
JL AIR BOX ELIMATOR BRACKET
NACS PARCKING BRAKE BLOCK OFF
OMF SEAT BRACKET
MAIER PLASTIC
NACS GRAPHICS
NACS SEAT COVER
K&K NUMBER PLATE BACK GROUNDS
TAG GRIPS
MSR CLUTCH LEVER AND PERCH
PRO TAPER BAR PAD
BILLET ALUMINUM GAS CAP
BLUE SHOCK COVERS
MODQUAD THROTLE LEVER
MODQUAD THROTLE COVER
YZ426F MOTOR 12.5:1 compression
WHITEBROS R4 FULL SYSTEM MODDED
PWR RADIATOR
OIL COOLER
BOYESEN QUICKSHOT ACCELERATOR PUMP COVER
TUSK CLUTCH PLATES
HINSON BASKET
YZ450 EXHAUST CAM
DYNO JET KIT
K&N AIR FILTER
WATER REPELLENT PRE FILTER SKIN
MOTION PRO CLUTCH CABLE
FREE FLO VENT LINE
PRIMARY DRIVE 39T REAR SPROCKET
JL 13T FRONT SPROCKET
PRIMARY DRIVE GOLD RACE CHAIN
GWC CASE SAVER
5 STROBE LED LIGHTS
PRODESIGN TETHER KILL
TUSK CARB VENT LINE
*way more to come*
Bring it Little Man,,,,,Fear of God and Common Sense will keep you Way behind me:cool: :D
This yz motor has 47hp stock. After i get it running again and get new front rims ill be buying nos but ill be mainly for looks.
  • 8 months later...
2007 TRX 400ex
less than 10 hours on it bought it in june of this year.
dyno jet stage 2 jet
k&n filter with outerwear, no lid
FMF Power bomb header pipe
HMF red powdercoated silencer
swing-arm alum skidplate
full chassis alum skid plate
hopefully more to come this spring
2007 TRX 400ex
Sounds pretty beefed up! Any pics?
    • By Trent Finnessey
    • By Dumass
