I just found this online and thought it looked pretty cool. It's some off brand by Well Motor.
Hunter 650 4WD Buggy Web I_Logic
Engine Type 4-Strokes, Water Cooled, Fully-Automatic
Cylinder Arrangement Double Cylinder
Transmission System Reverse N1230 Shaft Drive 4WD
Bore x Stroke (mm) 57x57.8
Piston Displacement (cc) 147.4
Compression Ratio 8.4:1
Maximum Power (kw/r/min) 14kw 4500r min
Maximum Torque (N.m./rpm) 14/kw/4500r
Starter System Electric/ Kick
Lubrication Forced pressure(wet sump)
Transmission Shaft Drive
Overall LxWxH (in) 88x50x44 inch
Wheel Base (in) 60
Seat Hight (in) 44
Min. Turning Radius (mm) 2800
Ground Clearance (in) 4
Rider Capacity 2 Person
Dry Weight (lb) 275
Brake (Front/Rear) Drum/Disc
Tyre, Front 25x10x12
Tyre, Rear 25x10x12
Ignition Type C.D.I
Fuel Tank Capacity (L) 12L
Engine Oil Capacity (L) 1L
Gear Oil Capacity (L)
Front Suspension Independent,Telescopic Arm
Rear Suspension Swing Arm
Parking Brake Mechanical Lock
Max. Load Capacity (lb) 210
Max. Speed (mi/hr) 45
battery 12V-9A
PACKING SIZE (in) 226x132x117 cm /G.W. 435 KGS NW: 410KGS
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By DaleJAM
    • By Parham
      My old quad needs new tires.  I am having a hard time finding the OEM size 25x10-10.  Anyone running more readily available 25x11-10?  Any issues?
    • By Coyote251
      service manual - 2016 Can-Am Outlander L-Series
