I just found this online and thought it looked pretty cool. It's some off brand by Well Motor.
Hunter 650 4WD Buggy Web I_Logic
Engine Type 4-Strokes, Water Cooled, Fully-Automatic
Cylinder Arrangement Double Cylinder
Transmission System Reverse N1230 Shaft Drive 4WD
Bore x Stroke (mm) 57x57.8
Piston Displacement (cc) 147.4
Compression Ratio 8.4:1
Maximum Power (kw/r/min) 14kw 4500r min
Maximum Torque (N.m./rpm) 14/kw/4500r
Starter System Electric/ Kick
Lubrication Forced pressure(wet sump)
Transmission Shaft Drive
Overall LxWxH (in) 88x50x44 inch
Wheel Base (in) 60
Seat Hight (in) 44
Min. Turning Radius (mm) 2800
Ground Clearance (in) 4
Rider Capacity 2 Person
Dry Weight (lb) 275
Brake (Front/Rear) Drum/Disc
Tyre, Front 25x10x12
Tyre, Rear 25x10x12
Ignition Type C.D.I
Fuel Tank Capacity (L) 12L
Engine Oil Capacity (L) 1L
Gear Oil Capacity (L)
Front Suspension Independent,Telescopic Arm
Rear Suspension Swing Arm
Parking Brake Mechanical Lock
Max. Load Capacity (lb) 210
Max. Speed (mi/hr) 45
battery 12V-9A
PACKING SIZE (in) 226x132x117 cm /G.W. 435 KGS NW: 410KGS
    • By Coyote251
    • By marcosphoto
    • By DaleJAM
    • By Parham
      My old quad needs new tires.  I am having a hard time finding the OEM size 25x10-10.  Anyone running more readily available 25x11-10?  Any issues?
